How can i use external captive portal? not exernalLoginPage
We are developing our hotspot management system, to raise the quality of our service, and to move to open source solutions. We are using many MT routerboards (e.g. 1100, 1200, 750G) that we use as hotspot gateway (serve login page, manage login requests and communicate with radius server) this simple structure is work fine.
Our goal is to separate mikrotik services to dedicated servers. !!!We would like to Posting Login informations (username , password) to external captive portal software in dedicated server!!!. After that the Captive software communicate with radius server, check user data, and start the radius session in appropriate MIKROTIK rb. We idntify te RBs from rb’s NASid.
My question is how can i do that?
Best regards
try this:
http://wiki.mikrotik.com/wiki/HotSpot_external_login_page
it’s not good for me. it’s just an external login page
i need an external captive portal software.
We would like to Posting Login informations (username , password) to external captive portal software in dedicated server!!!. After that the Captive software communicate with radius server, check user data, and start the radius session in appropriate MIKROTIK rb. We identify te RBs from rb’s NASid.
