Hi all,
Anyone meet this situation about recovery last good outside IP if make a mistake to change wrong outside IP address through remote login ?
Because remote outside IP is wrong, if I call to someone help to reset then IP will change to default not last correctly.
Cisco IOS have “running-config” and “startup-config” design, so if meet this situation I can directly reboot router, but I don’t know what method that RouterOS can restore this?
