How change to swos in fiberbox csr105
I want to change from router OS to sw OS in the fiberbox csr105 I just bougt, The terminal command does not work. /mike
Specifications for CRS105 (fiberbox) only mention RouterOS as supported OS. Specifications for CRS switches that support SwitchOS (e.g. CRS326) do mention that …
Strange that they call it a Outdoor Switch" then https://mikrotik.com/product/fiberbox outdoor router would be a better name.
How about CRS106 ? is it also RouterOS only ?
/mike
Check it yourself, specs for all switches are here.
I guess they call them switches even though they run ROS because their CPU is weak and unable of routing anywhere near wirespeed, but they feature decent switch chip capable of wirespeed switching.
Anyway, on most dual-OS devices ROS offers same set of features (if not more) and runs more stable. You can disable all routing features. Only administration interface is more complex, but I guess everybody can get some grip on it …
