How check OID
I am new on this Forum :slight_smile:
I have big problem a must get OID of port on switch d-link des 3526
could you help me ??
Right click on the object, select snmpwalk.
View the entire OID, find the oid that is probably the one your looking for… read the probe thread to learn if you have not already.
If you are missing the “NAMES” of the oids you need to download a mib for your device then drag and drop it into the mibs folder under the file heading.
Most these mibs are probably already in the dude, compare this list to the list of files/mibs and add the ones you are missing. I would only add mibs to the dude as a last step. More mibs doesn’t really matter if you can SNMPWALK and find what you want…
The dude will restart if you place a new mib in the files/mib folder.
MIBs :
  • 802.1Q Q-BRIDGE-MIB (RFC 2674)
  • 802.1p P-BRIDGE-MIB (RFC 2674)
  • MIB-II (RFC 1213)
  • Bridge MIB (RFC 1493)
  • RMON MIB (RFC 1757) Group 1, 2, 3, 9 (Alarm, Statistics, History, Event)
  • IGMP MIB (RFC 2933)
  • IF MIB (RFC 2933)
  • Ethernet-like MIB (RFC 1643)
  • PING-MIB and TRACEROUTE-MIB (RFC 2925)
  • ICMP Ping by MIB
  • Rate Limiting by MIB
  • Save Configuration by MIB
  • 802.1w Setting and Read by MIB
  • Port Interface MIB-II Trap (RFC 1215)
  • D-Link Enterprise MIB
