I’m curious as to how close two SXTs can be placed without radio damage, and what the suggested power/protocol setting would be?
Thanks in advance!
Thanks in advance!
ehhh, put them close together and put the power high until one of the radios is gone. Then you know! ![]()
If signal strength on the receiving end is less then -30 I start to worry about my radios.
Signals between -45 and -70 are best where around -60 is ideal (with enough s/n ratio)
I’ll let you demonstrate - with your radios naturally.
I tried 5 meters at minimum power without apparent damage during a couple days. NV2 protocol, 40 Mhz channel, about 160 Mbps real total bandwith.
If you rise power, then distorsion appear at receiving side and link reliability and bandwith drop dramaticaly.
