How close can you use channels in 802.11a.
Hello.
I am wondering. :question: :question: :blush:
Mikrotik supports several different steps in the 5.x band.
Both 5 GHz with 5 MHz step, with 10 MHz step, and normal with 20 MHz step.
How many channels are useable on the same tower?
Can I use one with 5.505 and the next with 5.510 ?
If I use turbo how close can they be put in this setup?
Your biggest issue is channel bleed thru the pigtails.
Please see my previous post regarding required channel spacing at the same POP.
SMA
Read the faq or use search. :blush: :blush:
I believe you are refering to this topic.
http://forum.mikrotik.com//viewtopic.php?t=8139&highlight=
Nice research.
Thanks.
Henrik
You may be able to shield your pigtails by feeding them through some thin copper tubing.
Grounding the copper should reduce the amount of crosstalk between the pigtails.
