Hello, I need configure Mikrotik as router for internet access. Scheme is: PC->Mikrotik->Internet. I configure Mikrotik by using Winbox. Here is screen:
you will have to look up certain things in the manual for this to start to work.
check if you have set up source nat, so that packets that come from PC have correct outoging ip address
check if you have set up default route that points to your gateway.
also, if you want to be able to ping some domain names from router, you have to set up dns server address to connect to.
