I can pass my ISP modem in a Bridgged mode, to do so I have to enter the MAC of the interface that is connected to the ISP modem.
/interface print
So far no problem, but when I do so, I loss the connect to the WWW
The ISP do not explain more.. I suppose I have to use a PPPoE client ?
is the Hex are capable of such ?
Thanks.
What ISP do you have? Not any information on their site about running a modem in bridge mode?
In regards to PPPoE:
https://help.mikrotik.com/docs/spaces/ROS/pages/2031625/PPPoE#PPPoE-PPPoEClient
Thank you @erlinden
no, I didn’t find any info… I will write them today, but I have little hope..
My ISP is MoblieViking that actually use the Proximus infrastructure and end user hardware…
Thanks for the link , I’ll check that.
Thank you @Sebastia !
I did a search in their help, but no result returned, but I guess It was a technical problem at the time.. they use a lot of external library to run their website…
So I’ve checked the two link you found ( again thanks )
So for the configuration of the PPPoE they seem to not give a lot of details…
But indeed on the post regarding the fritzboz they say ~“You can request the credentials by contact us”
So i’ll try to reach them… (finger cross)
