How Customize Mikroitk Invironment
How can I customize Mikroitk Router -OS Environment ???
You can move the windows and set the columns in winbox.
Explain more please
Explain your requirements in details please.
in want customize terminal cLI replace mikrotik by custom name in terminal
customize winbox menue
and more
i see edit 2 npk file by linux editor and upgrade device by this file
then customized
First can be done by branding maker if you are a distributor. Second is not supported at all. You can just add or remove the packages that has effect on the menu.
i Have npk file i need to editor files
