How do I add Google earth background to my Dude?
I am trying to add a Google Earth backgroung to my Dude. Most bof my network map is already in place. Is there a way to add this background without destroying the network map that is in place?
Its just a background image. Export and then you can use that image.
Dennis Burgess
St. Louis Network Engineering Services
http://www.mikrotikconsulting.com
dmburgess@mikrotikconsulting.com
Certified Mikrotik Engineer
Thanks Dennis, I met you in Orlando. I found it was easy to find the Google Earth background image I liked, save that image, open with paint and then apply to DUDE background.
