Two weeks ago I fired one of my my employee
He had the passwords for all my stations. Before I decided to fire him, I changed the passwords, but by mistake I forgot two change the pas to two important routers…
yesterday I saw that the log in one of them is missing and I assume he has logged in and do some changes …
Any suggestions, where should I look for hack and thing like that…
I can do reset config, but not now… I need to go physically to the device…
I checked almost everything, noting seems to be infected… but in google you can find so much ways to do something bad…
Is there anything useful that I can do to check…
last night I disabled all the ports in the router and left it alone to the internet and tried to torch the wan interface to see if there are any connection to somewhere, there are non…
is there anything else that can be checked ?
dont be hysterical
if you reboot unit, the log will be empty - unless it is set to be stored
without password and user there is no way u can log in to MT OS
if it is rebooted NOT from command, it will say
*system,error,critical router was rebooted without proper shut down
the router gets power from UPS and other devices connected to the router on the same power have a long uptime
So the router was rebooted by command…
I know, as u know, as everybody know that if you do changes everything is going into the log, but to remove log u reboot… → in my case, because I haven’t configure the logging write!
I’m not “hysterical”, I’m just learning from my mistakes…
For me and my company its good to deliver nice and safe services to my clients… I’m always considering the unexpected!!!
So I am just asking for suggestions where to look for “infections”
answering this may help others in the time as well !
That was what I was asking
any others ?
I already went there and did reset config…
Am just curious how to catch viruses done on mikrotik, cause in google you can find lots of scripts and mechanism for sending passwords and things like that…
Now I just want to make myself an algorithm of what I should check to sleep well when I have doubts for any of my devices
