How do I configure a HAP ac as a wireless access point
Hi all,
I have a spare RouterBOARD 962UiGS-5HacT2HnT router. I want to configure it as a wireless access point. What do I need to do?
Could you please give me instructions from the terminal? I am blind so prefer using the commanddline because of accessibility challenges with the web fig interface and winbox.
I have done the following so far after resetting the router’s configuration to factory defaults.
  1. Disabled the dhcp server.
  2. Disabled the dhcp-client.
  3. Setup the wireless interface namely wlan2 with its associated security profile.
  4. The router has a fixed static IP address on my lan and i have set its gateway.
What do I have to do next?
Pranav
Since you have disable dhcp server I’m going to assume that you want to have this just passthrough up to your router. For commands I’m assuming you aren’t running version 7 (pretty sure they are same, but haven’t messed with it). You also mentioned factory defaults, so:
You should already have a bridge interface. Can check by doing
interface bridge print
Example output where there is a bridge
 #   NAME        MTU ACTUAL-MTU L2MTU
 0 R bridge1        auto       1500  1598
If you don’t have a bridge, please create one with
 interface bridge add
Created in this way it will be named “bridge1”
Once you have verified that you have a bridge you need to make sure that the interface you are using to connect to your router and the wlan2 interface are both members of the bridge. To check:
 interface bridge port print
Example output
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE                      BRIDGE                      HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 5 I H ether2                         bridge1                     yes    1     0x80         10                 10       none
 6 I   wlan2                          bridge1                            1     0x80         10                 10       none
If the port you are using to go to the router is not here please add it by:
interface bridge port add interface=ether1 bridge=bridge1
Once you have the uplink port and your wlan2 in the same bridge, assuming DHCP is set up for that port on the router your Wi-Fi clients will get IPs from it. You’ll also want to put the IP address on the bridge interface instead of on the uplink port. If that IP was 10.9.8.7/29 you could do:
ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0 D 192.168.0.6/24     192.168.0.0     MGMT vlan 666
 1   10.9.8.7/29        10.9.8.0        ether1
 2 X 192.168.88.1/24    192.168.88.0    bridge1
 ip address set 1 interface=bridge1
If matching the index number is difficult, you could also do:
ip address set [find address="10.9.8.7/29"] interface=bridge1
Many thanks for your lucid instructions. I however am making a mistake somewhere. See the below verbose export. When I take the router to the location where it needs to be, I do not get any wireless signals from the router. I did try plugging in the LAN cable without successs. I can however access the router over thee LAN so something is working.
Pranav
oct/07/2021 23:03:03 by RouterOS 6.48.4
software id = 44P9-FNDB
model = RouterBOARD 962UiGS-5HacT2HnT
serial number = 8A7708EAC3B4
add admin-mac=CC:2D:E0:AB:76:59 ageing-time=5m arp=enabled arp-timeout=auto
auto-mac=no comment=defconf dhcp-snooping=no disabled=no fast-forward=yes
forward-delay=15s igmp-snooping=no max-message-age=20s mtu=auto name=
bridge priority=0x8000 protocol-mode=rstp transmit-hold-count=6
vlan-filtering=no
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled
arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 loop-protect=default
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=
CC:2D:E0:AB:76:58 mtu=1500 name=ether1 orig-mac-address=CC:2D:E0:AB:76:58
rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=
CC:2D:E0:AB:76:59 mtu=1500 name=ether2 orig-mac-address=CC:2D:E0:AB:76:59
set [ find default-name=ether3 ] advertise=
CC:2D:E0:AB:76:5A mtu=1500 name=ether3 orig-mac-address=CC:2D:E0:AB:76:5A
set [ find default-name=ether4 ] advertise=
CC:2D:E0:AB:76:5B mtu=1500 name=ether4 orig-mac-address=CC:2D:E0:AB:76:5B
set [ find default-name=ether5 ] advertise=
CC:2D:E0:AB:76:5C mtu=1500 name=ether5 orig-mac-address=CC:2D:E0:AB:76:5C
poe-out=auto-on poe-priority=10 power-cycle-interval=none
!power-cycle-ping-address power-cycle-ping-enabled=no
!power-cycle-ping-timeout rx-flow-control=off speed=1Gbps
tx-flow-control=off
set [ find default-name=sfp1 ] advertise=
10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto
auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no
full-duplex=yes l2mtu=1600 loop-protect=default
CC:2D:E0:AB:76:5D mtu=1500 name=sfp1 orig-mac-address=CC:2D:E0:AB:76:5D
rx-flow-control=off sfp-shutdown-temperature=95C speed=1Gbps
tx-flow-control=off
/queue interface
set bridge queue=no-queue
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 2 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 3 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 4 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 5 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set [ find name=all ] comment="contains all interfaces" exclude="" include=""
name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include=""
name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude=""
include="" name=dynamic
set [ find name=static ] comment="contains static interfaces" exclude=""
include="" name=static
add comment=defconf exclude="" include="" name=WAN
add comment=defconf exclude="" include="" name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet
default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types="" disable-pmkid=no
eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m
interim-update=0s management-protection=disabled
management-protection-key="" mode=none mschapv2-password=""
mschapv2-username="" name=default radius-called-format=mac:ssid
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=
"" wpa2-pre-shared-key="my key"
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=
no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=
3 area="" arp=enabled arp-timeout=auto band=2ghz-b/g/n basic-rates-a/g=
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-XX
compression=no country=india default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=
yes disable-running-check=no disabled=yes disconnect-timeout=3s distance=
indoors frame-lifetime=0 frequency=auto frequency-mode=regulatory-domain
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m
cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2
3" hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 installation=indoor
interworking-profile=disabled keepalive-frames=enabled l2mtu=1600
mac-address=CC:2D:E0:AB:76:5F max-station-count=2007 mode=ap-bridge mtu=
1500 multicast-buffering=enabled multicast-helper=default name=wlan1
noise-floor-threshold=default nv2-cell-radius=30 nv2-downlink-ratio=50
nv2-mode=dynamic-downlink nv2-noise-floor-offset=default
nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 nv2-security=
disabled nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both
radio-name=CC2DE0AB765F rate-selection=advanced rate-set=default
rx-chains=0,1,2 scan-list=default secondary-channel="" security-profile=
default skip-dfs-channels=disabled ssid=old station-bridge-clone-mac=
00:00:00:00:00:00 station-roaming=disabled supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1,2
tx-power-mode=default update-stats-interval=disabled vlan-id=1 vlan-mode=
no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100
wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11
wmm-support=disabled wps-mode=push-button
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=
2 area="" arp=enabled arp-timeout=auto band=5ghz-a/n/ac basic-rates-a/g=
6Mbps bridge-mode=enabled channel-width=20/40/80mhz-XXXX compression=no
country=india default-ap-tx-limit=0 default-authentication=yes
default-client-tx-limit=0 default-forwarding=yes disable-running-check=no
disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0
frequency=auto frequency-mode=regulatory-domain frequency-offset=0
mac-address=CC:2D:E0:AB:76:5E max-station-count=2007 mode=ap-bridge mtu=
1500 multicast-buffering=enabled multicast-helper=default name=wlan2
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink
radio-name=CC2DE0AB765E rate-selection=advanced rate-set=default
default skip-dfs-channels=disabled ssid=Periscope5G
station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=disabled
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
tdma-period-size=2 tx-chains=0,1,2 tx-power-mode=default
update-stats-interval=disabled vht-basic-mcs=mcs0-7 vht-supported-mcs=
mcs0-9,mcs0-9,mcs0-9 vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=
disabled wireless-protocol=802.11 wmm-support=disabled wps-mode=
push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:
17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H
T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-
7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
7:17"
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01$(CLIENT_MAC)"
set hostname code=12 name=hostname value="$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=
flash/hotspot html-directory-override="" http-cookie-lifetime=3d
http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit=""
smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none
!insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=
default !parent-queue !queue-type shared-users=1 status-autorefresh=1m
transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no use-responder-dns=
exclusively
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m
dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1
lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=
aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=
modp1024
add address-pool=default-dhcp authoritative=yes disabled=yes interface=bridge
lease-script="" lease-time=10m name=defconf use-radius=no
/ppp profile
set *0 address-list="" !bridge !bridge-horizon bridge-learning=default
!bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server
!idle-timeout !incoming-filter !insert-queue-before !interface-list
!local-address name=default on-down="" on-up="" only-one=default
!outgoing-filter !parent-queue !queue-type !rate-limit !remote-address
!session-timeout use-compression=default use-encryption=default use-mpls=
default use-upnp=default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon bridge-learning=default
!local-address name=default-encryption on-down="" on-up="" only-one=
default !outgoing-filter !parent-queue !queue-type !rate-limit
!remote-address !session-timeout use-compression=default use-encryption=
yes use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32
pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0
pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0
pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address
pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB
pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set sfp1 queue=only-hardware-queue
set wlan1 queue=wireless-default
set wlan2 queue=wireless-default
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id
!confederation disabled=no ignore-as-path-len=no name=default out-filter=
"" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=
no redistribute-rip=no redistribute-static=no router-id=0.0.0.0
routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id
!domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20
!mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
!routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-password=""
authentication-protocol=MD5 disabled=no encryption-password=""
encryption-protocol=DES name=public read-access=yes security=none
write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=flash/log disk-lines-per-file=1000
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=
0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=
bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w
eb,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude" skin=
default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa
ssword,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude" skin=
default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,
winbox,password,web,sniff,sensitive,api,romon,tikapp,!dude" skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled
mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path=""
require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=no crl-store=ram crl-use=no
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=
defconf disabled=no edge=auto fast-leave=no frame-types=admit-all
horizon=none hw=yes ingress-filtering=no interface=ether2
internal-path-cost=10 learn=auto multicast-router=temporary-query
path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no
restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes
unknown-unicast-flood=yes
horizon=none hw=yes ingress-filtering=no interface=ether3
horizon=none hw=yes ingress-filtering=no interface=ether4
horizon=none hw=yes ingress-filtering=no interface=ether5
horizon=none hw=yes ingress-filtering=no interface=sfp1
horizon=none ingress-filtering=no interface=wlan1 internal-path-cost=10
learn=auto multicast-router=temporary-query path-cost=10 point-to-point=
auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no
horizon=none ingress-filtering=no interface=wlan2 internal-path-cost=10
/interface bridge port-controller
disabled
set bridge=none cascade-ports="" switch=none
/interface bridge port-extender
disabled
set control-ports="" excluded-ports="" switch=none
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no
use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes
tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=
1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m
udp-stream-timeout=3m udp-timeout=10s
set discover-interface-list=static lldp-med-net-policy-vlan=disabled
protocol=cdp,lldp,mndp
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes
arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes
max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=
yes send-redirects=yes tcp-syncookies=no
/interface detect-internet
set detect-interface-list=none internet-interface-list=none
lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2
caller-id-type=ip-address default-profile=default-encryption enabled=no
ipsec-secret="" keepalive-timeout=30 max-mru=1450 max-mtu=1450
max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=no
add comment=defconf disabled=no interface=bridge list=LAN
add comment=defconf disabled=no interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=
no keepalive-timeout=60 mac-address=FE:2E:09:27:3D:D8 max-mtu=1500 mode=
ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500
max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any
verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names=""
caps-man-names="" certificate=none discovery-interfaces="" enabled=no
interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.5.6/24 comment=defconf disabled=no interface=bridge
network=192.168.5.0
add address=192.168.3.4/8 disabled=no interface=ether1 network=192.0.0.0
/ip cloud
set ddns-enabled=no ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-client
add add-default-route=yes comment=defconf default-route-distance=1
dhcp-options=hostname,clientid disabled=yes interface=ether1
use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set accounting=yes interim-update=0s store-leases-disk=5m
add address=192.168.5.0/24 caps-manager="" comment=defconf dhcp-option=""
dns-server="" gateway=192.168.5.6 netmask=24 ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-concurrent-queries=100 max-concurrent-tcp-sessions=20
max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s
servers=192.168.3.1 use-doh-server="" verify-doh-cert=no
/ip dns static
add address=192.168.5.6 comment=defconf disabled=no name=router.lan ttl=1d
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes
ipsec-policy=out,none out-interface-list=WAN !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users"
disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=
all src-address=::/0 template=yes
/ip ipsec settings
set accounting=yes interim-update=0s xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster
cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no
max-cache-object-size=2048KiB max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no
src-address=::
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref
!bgp-med !bgp-origin !bgp-prepend !check-gateway disabled=no distance=1
dst-address=0.0.0.0/0 gateway=192.168.3.1 !route-tag !routing-mark scope=
30 target-scope=10
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443 tls-version=any
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729 tls-version=any
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/flash/pub
disabled=no max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set auth-method=none connection-idle-timeout=2m enabled=no max-connections=
200 port=1080 version=4
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no
host-key-size=2048 strong-crypto=no
/ip tftp settings
set max-block-size=4096
/ip traffic-flow
set active-flow-timeout=30m cache-entries=32k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes
dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes
igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes
ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=
yes nat-dst-port=yes nat-events=no nat-src-address=yes nat-src-port=yes
out-interface=yes packets=yes protocol=yes src-address=yes
src-address-mask=yes src-mac-address=yes src-port=yes sys-init-time=yes
tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes
ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no
use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public
trap-generators=temp-exception trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=Asia/Kolkata
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=
"jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=wlan1 leds=wlan1-led type=wireless-status
set 1 disabled=no interface=wlan2 leds=wlan2-led type=wireless-status
set 2 disabled=no interface=sfp1 leds=sfp-led type=interface-activity
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
/system routerboard settings
set auto-upgrade=yes boot-device=nand-if-fail-then-ethernet boot-protocol=
bootp force-backup-booter=no protected-routerboot=disabled
reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard reset-button
set enabled=no hold-time=0s..1m on-event=""
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes ping-start-after-boot=5m
ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set allowed-interface-list=all
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00 secrets=""
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
secrets=""
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
secret="" sim-pin=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any
filter-interface="" filter-ip-address="" filter-ip-protocol=""
filter-ipv6-address="" filter-mac-address="" filter-mac-protocol=""
filter-operator-between-entries=or filter-port="" filter-size=""
filter-stream=no memory-limit=100KiB memory-scroll=yes only-headers=no
streaming-enabled=no streaming-server=0.0.0.0:37008
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=yes
stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s
use-radius=no
Can you post a non verbose option please LOL
Why are there two IP addresses??
ip address
network=192.168.5.0
Yes, regular export or compact export are much easier to read through. Your wlan2 is enabled and in ap bridge as well as a bridge port so it should be broadcasting and passing through traffic to anything on ether2, ether3, ether4, ether5, or sfp1. If your devices are 5GHz compatible otherwise, it’s possible that autochannel landed on something your devices can’t detect. Could try setting a manual frequency to test, or enable wlan 1 with it’s old ssid to check if that is detected by your devices.
interface wireless set 1 frequency=5180
Sorry about the verbose export and thanks for reminding me about the hide sensitive option.
I have 2 IP addresses because the router asked me for a lan side network address. I had to put something in which I did. Otherwise, web fig was not applying the configuration. I am happy to start from scratch. Please see below for the compact export.
The IP address 192.168.3.4 is my LAN ip address which I want to assign to the router.
Pranav
# oct/08/2021 05:16:11 by RouterOS 6.48.4
# software id = 44P9-FNDB
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7708EAC3B4
add admin-mac=CC:2D:E0:AB:76:59 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=india distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=old wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=india disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge ssid=Periscope5G \
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.5.6/24 comment=defconf interface=bridge network=\
    192.168.5.0
add address=192.168.3.4/8 interface=ether1 network=192.0.0.0
/ip dhcp-client
add address=192.168.5.0/24 comment=defconf gateway=192.168.5.6 netmask=24
set allow-remote-requests=yes servers=192.168.3.1
/ip dns static
add address=192.168.5.6 comment=defconf name=router.lan
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add distance=1 gateway=192.168.3.1
/system clock
set time-zone-name=Asia/Kolkata
Use Code Tag while posting code. Looks much better.
Eks:
/interface wireless
192.168.5.0
/ip dhcp-client
/ip dns static
/system clock
But anyway, that config should have your SSID being broadcast. Might be an issue with either the hap or the device you’re checking wireless visibility with. Have you tried enabling wlan1 to check if your devices can see it? Could also see if wlan2 can detect other ssid when it performs a scan, assuming others are near you.
Many thanks for the configuration. I found the problem. I had not assigned a dhcp client to the bridge.
Pranav
