How do I connect Mullvad Wireguard Client on dual wan using routing rules?
How do i get WG01_MULLVAD to use WAN1 using routing table? I tried many different combinations in Routing Rules with source set to wireguard interface ip, destination etc but it always used the default route.
hard to say what you are doing wrong without the config (evidence).
# mar/07/2023 02:10:21 by RouterOS 7.6
# software id =
set [ find default-name=ether3 ] name=LAN
set [ find default-name=ether1 ] disable-running-check=no name=MANAGMENT_PORT
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] mtu=1480 name=WAN2
/interface pppoe-client
add disabled=no interface=WAN1 name=WAN1_PPPOE user=user
/interface wireguard
add listen-port=13231 name=WIREGUARD_WAN1
add listen-port=13239 name=WIREGUARD_WAN2
/interface vlan
add interface=LAN name=FREEWIFI vlan-id=140
add name=dhcp_pool0 ranges=192.168.4.10-192.168.4.254
add name=dhcp_pool1 ranges=192.168.100.10-192.168.100.254
add name=dhcp_pool2 ranges=192.168.69.2-192.168.69.254
add address-pool=dhcp_pool0 interface=LAN lease-time=1h name=DHCP_LAN
add address-pool=dhcp_pool1 interface=MANAGMENT_PORT name=dhcp1
add address-pool=dhcp_pool2 interface=FREEWIFI lease-time=1h name=dhcp2
/routing table
add disabled=no fib name=WAN1_ROUTE
add disabled=no fib name=WIREGUARD_GROUP
add disabled=no fib name=WAN1_ROUTE_WIREGUARD
set discover-interface-list=all
/interface wireguard peers
add allowed-address=0.0.0.0/0,::/0 endpoint-address=138.1.1.1 endpoint-port=51820 interface=\
    WIREGUARD_WAN1 persistent-keepalive=10s public-key=""
    WIREGUARD_WAN2 persistent-keepalive=10s public-key=""
add address=103.1.1.1.1/24 interface=WAN2 network=103.1.1.0
add address=192.168.4.1/22 interface=LAN network=192.168.4.0
add address=192.168.100.235/24 interface=MANAGMENT_PORT network=192.168.100.0
add address=10.66.19.40 interface=WIREGUARD_WAN1 network=10.66.19.40
add address=192.168.69.1/24 interface=FREEWIFI network=192.168.69.0
add address=10.64.149.211 interface=WIREGUARD_WAN2 network=10.64.149.211
/ip dhcp-client
add interface=MANAGMENT_PORT
add address=192.168.4.0/22 dns-server=192.168.100.230 gateway=192.168.4.1
add address=192.168.69.0/24 dns-server=192.168.100.235 gateway=192.168.69.1
add address=192.168.100.0/24 gateway=192.168.100.2
set allow-remote-requests=yes servers=1.1.1.1
add action=drop chain=input comment="Block access to RouterOS services" dst-port=80,443,8291,8728,8729 \
    protocol=tcp src-address=192.168.69.0/24
add action=accept chain=input connection-state=established,related
add action=drop chain=input connection-state=invalid
add action=drop chain=input in-interface=WAN2
/ip firewall mangle
add action=change-mss chain=forward new-mss=1500 out-interface=WIREGUARD_WAN1 passthrough=yes protocol=\
    tcp tcp-flags=syn tcp-mss=1000-65535
add action=change-mss chain=forward new-mss=1500 out-interface=WIREGUARD_WAN2 passthrough=yes protocol=\
add action=masquerade chain=srcnat comment="DEFAULT NAT" out-interface=WAN1_PPPOE
add action=masquerade chain=srcnat comment="DEFAULT NAT" out-interface=WAN2
add action=masquerade chain=srcnat comment="DEFAULT NAT" out-interface=MANAGMENT_PORT
add action=masquerade chain=srcnat comment="DEFAULT NAT" out-interface=WIREGUARD_WAN1
add action=masquerade chain=srcnat comment="DEFAULT NAT" out-interface=WIREGUARD_WAN2
add comment="MAIN ROUTE" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=WAN1_PPPOE pref-src="" \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add comment="POLICY ROUTE WAN1 " disabled=no distance=1 dst-address=0.0.0.0/0 gateway=WAN1_PPPOE \
    pref-src="" routing-table=WAN1_ROUTE scope=30 suppress-hw-offload=no target-scope=10
add comment="POLICY ROUTE WAN1" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=103.1.1.1.1 \
add comment="POLICY ROUTE PROXMOX" disabled=no distance=1 dst-address=192.168.100.0/24 gateway=\
    192.168.100.2 pref-src="" routing-table=WIREGUARD_GROUP scope=30 suppress-hw-offload=no target-scope=\
    10
add check-gateway=ping comment="MAIN ROUTE" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    103.1.1.1.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add comment="CHECK ROUTE WAN1" disabled=no distance=1 dst-address=1.1.1.1/32 gateway=WAN1_PPPOE \
    pref-src="" routing-table=main scope=11 suppress-hw-offload=no target-scope=10
add comment="CHECK ROUTE WAN2" disabled=no distance=1 dst-address=1.1.1.2/32 gateway=103.1.1.1.1 \
add check-gateway=ping comment="RECURSIVE ROUTE WAN1" disabled=no distance=1 dst-address=0.0.0.0/0 \
    gateway=1.1.1.1 pref-src="" routing-table=WAN1_ROUTE scope=30 suppress-hw-offload=no target-scope=\
    11
add check-gateway=ping comment="RECURSIVE ROUTE WAN2" disabled=no distance=2 dst-address=0.0.0.0/0 \
    gateway=1.1.1.2 pref-src="" routing-table=WAN1_ROUTE scope=30 suppress-hw-offload=no \
    target-scope=11
add comment="ROUTE WIREGUARD PCS THROUGH TUNNEL" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    WIREGUARD_WAN1 pref-src="" routing-table=WIREGUARD_GROUP scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 address
add address=fc00:-----/128 advertise=no interface=WIREGUARD_WAN1
/routing rule
add action=lookup-only-in-table comment="POLICY ROUTE WAN2 DEVICE OVER WAN2 GATEWAY" disabled=no interface=\
    LAN src-address=192.168.4.243/32 table=WAN1_ROUTE
add action=lookup-only-in-table comment="POLICY ROUTE WAN1 DEVICE OVER WAN1 GATEWAY" disabled=no \
    interface=LAN src-address=192.168.4.242/32 table=WAN1_ROUTE
add action=lookup-only-in-table disabled=no interface=LAN src-address=192.168.4.253/32 table=\
    WIREGUARD_GROUP
add action=lookup-only-in-table disabled=no interface=LAN src-address=192.168.4.240/32 table=\
    WIREGUARD_GROUP
add action=lookup-only-in-table disabled=no interface=LAN src-address=192.168.4.254/32 table=\
    WIREGUARD_GROUP
i hope i hid all the stuff that should be hidden. all public ips have been changed.
(1) For allowed IPs you only need the one entry 0.0.0.0/0
(2) I dont understand why you have defined ether1 twice in your /interface ethernet settings ???
You have a subnet on ether1 plus WAN pppoe??? Too confusing for me LOL
SO you have three WANS?? Two running off ether1
/ip dhcp-client
add action=masquerade chain=srcnat comment=“DEFAULT NAT” out-interface=WAN1_PPPOE
add action=masquerade chain=srcnat comment=“DEFAULT NAT” out-interface=WAN2
add action=masquerade chain=srcnat comment=“DEFAULT NAT” out-interface=MANAGMENT_PORT
(3) The wireguard IP addresses need work …
add address=10.66.19.40 interface=WIREGUARD_WAN1 network=10.66.19**.40**
add address=10.64.149.211 interface=WIREGUARD_WAN2 network=10.64.149**.211**
TO:
add address=10.66.19.40**/24** interface=WIREGUARD_WAN1 network=10.66.19**.0**
add address=10.64.149.211**/24** interface=WIREGUARD_WAN2 network=10.64.149**.0**
(4) Do any of your WANs provide a public IP, if so your firewall rules are lacking…
and make no sense,
(5) Why duplicates in tables…
/routing table
(6) I see no routing for wireguard2
Without understanding what is going on with WAN1, I am unable to assist.
Also would need better understanding of what users or subnets are going through each wireguard connection (looks like 4 users but what about proxmox?)
So, I fixed it by changing the ports of remote endpoints. WAN1 will connect over 51820 and WAN2 over 57000.
Then I created a mangle rule with dst-address= dst-port=57000 and action set to Mark Routing with routing mark as the WAN2 mark. In routes, i just created a route with gateway set to WAN2’s gateway and mark set to WAN2 mark.This way I can differentiate which Wireguard Interface connects using which Isp by using endpoint ports.
This works i suppose. But I think there must be a way to do it in cases where endpoints and ports of the remote servers are same.:person_shrugging:
