how do I enable romote connection
how do I enable romote connection when I need someone login to my router and after that disable it?
my suggestion:
allowing someone to log on to your network may cause security penetration, or may cause your network leak to compromise, but if you’r realy sure… then please try links below :
try to use VPN OR IPTables/IPChains OR IPSec/IP Filtering!
Filter
To add a firewall rule which drops all TCP packets that are destined to port 135 and going through the router, use the following command:
(the commands will drop all connection to port 135)
/ip firewall filter add chain=forward dst-port=135 protocol=tcp action=drop
To deny acces to the router via Telnet (protocol TCP, port 23), type the following command:
/ip firewall filter add chain=input protocol=tcp dst-port=23 action=drop
or for complete list, please read manual :
http://www.mikrotik.com/testdocs/ros/2.9/ip/filter.php
Firewall address lists allow to create a list of IP addresses to be used for packet matching.
http://www.mikrotik.com/testdocs/ros/2. … s_list.php
IP Security
http://www.mikrotik.com/testdocs/ros/2.9/ip/ipsec.php
You could also add an account for them to Telnet/SSH/HTTP/Winbox into your router. Then when they are done you can disable the account.
-Louis
I want doing like that ,when I Enable rule, you can use Public IP :8080(OR any) then webbox will appear.and in winbox Public IP name & password can login.
thanks!
