I need to print the queues with target=unknown. How should I filter for them?
/queue simple print where target=??
The queue target becomes empty when a client is offline.
What do you mean with traget=unknown? Do you mean target=0.0.0.0/0?
You can not create queue without specifying the target.
Usually to find something what has no value you should use “!”.
Example:
“/ip firewall filter print where !src-address”
Tried it, did not work ![]()
Scenario:
I add a simple queue and assign target to a connected PPPoE client. But after the client gets disconnected, the target becomes unknown. I need to clean up any unassigned queues. To find them I need to filter them by the empty target.
I found a solution, API syntax:
/queue/simple/print ?<target=0
/queue simple> print where invalid !disabled
