Hi All
i want to redirect my clients to a page either than the net if they are due to pay their monthly bills.
How do i do this without the client having internet access
with a nat rule. dst-nat with action dst-nat:
/ip firewall nat add chain=dstnat src-address=1.1.1.1 action=dst-nat to-addresses=192.168.0.109
assuming 1.1.1.1 is the bad client, and 192.168.0.109 is your webserver
… and bad client cannot be in the same IP subnet as local web server where he is redirected to.
do i put this firewall command in the client’s radio or the base station
base station
ok i will do that and get back to you
can i use ip pool instead od certain ip address?
i’d like to change ip pools in user manager via some php script.
or is there better way do do that ?
