How do I setup 2 x Wan (two internet connections) and 2 x Vlans (Access points on )
2 x Internet Connections (WANs) (Internet connection 1, and internet connection 2) Seprate ADSL companies
1 x MikroTik RouterBoard RB2011UiAS-2HnD-IN WiFi Broadband Routers
4 x Ubiquiti UniFi UAP Wireless-N Managed PoE Access Point (300Mbps)
1 x (PC running unifi controller) - Controller allows for Zero Roaming Handover seamless.
I want to do the following configeration but find it very hard because I am very new to this, any help is much appricated
I want to setup two seprate VLANs in order to split the network for security and traffic. The family VLAN100 (used for Wifi_family) willl have lots of streaming etc, I will enable QOS later (any ideas about that).
VLAN100 (192.168.0.1) —> internet connection 1 (WAN1)
VLAN200 (192.168.1.1) → internet connection 2 (WAN 2)
Also VLAN100 can use WAN2 as the backup but WAN2 can never use WAN1
The Ubiquiti UniFi UAP has Wifi_Family (On the controller for this do I setup the VLANs to seprate) and Wifi_work.
Also I want the MikroTik RouterBoard RB2011UiAS-2HnD-IN to be the DHCP servers
I want to also setup DNS 8.8.8.8 for all clients connecting.
I hope this makes sense.
Thank you for the help in advance.
I think is not possible because you only had one Eth1/PoE port (WAN1), then WAN 2 becomes like a gateway or bridge.
OK I see. What about forgetting about the fail over and just setting up two different vlans over two differenthings with gateways as eth1 and eth2 with no routing between the vlans
Any help would be great
Thank you.
