How do I setup UPnP on my router?
Hi guys!
This question will seem lame I suppose but I’m pretty much begginer with my Mikrotik router (I have v5.22). I’m trying to set up UPnP so I can use uTorrent and Xbox Live without problems.
When I go to the IP - UPnP, I switch UPnP enable but it seems I need to do something else also because either Xbox Live or uTorrent doesnt find UPnP router.
You have to specify internal and external interface.
there some examples in the docs:
http://wiki.mikrotik.com/wiki/Manual:IP/UPnP
you can also try to set up a SOCKS Proxy server on RouterOS and than you only have to open the used protocol
(TCP or UDP) and the port numbers!
