How do you negate a command?
I want to bulk change some CAPSMAN entries, previously i’ve specified some values that I want to omit, i.e. local-forwarding in datapath. Problem is I can’t find a way to actually remove this command. I can go in and run a command such as
/caps conf set [find where name=“somethingsomething”] datapath.local-forwarding=
But I must manually specify yes or no. I don’t want either of these because that’s a hard override of using a datapath template. I instead want to entirely remove the datapath.local-forwarding command. Same as ticking the up arrow in winbox
Is there a way to do this?
/caps conf unset [find where name="somethingsomething"] datapath.local-forwarding
