Hi all just got my mikrotik firewall. Using winbox to configure it by an ethernet cable.
I changed time but when I reboot it, it resets itself to 1970!
How can I make it keep the setting?
Configure yours NTP Client,
http://wiki.mikrotik.com/wiki/Manual:System/Time
There’s no battery so it won’t save time. Use NTP.
Ok thanks.
Also how do I make it save changes I do in its config? Or it does save automatically without having the need to copy the config to flash (like cisco ios)?
Final query - how do I enable ftp so that I retrieve configs from it?
cheers ![]()
You not need to save config. Config saves automaticali when you click OK in winbox or press enter in terminal.
FTP is enabled by default.
In terminal you type: export file=something
And get it by ftp or drag & drop from winbox-files.
config will save automatically
unless u talk about backup is should do manual
about ftp
ip service> enable ftp
Yep all worked. Thanks a lot ![]()
