So, I setup graphing for the ports pretty easily (pretty much just turned them on), but how do I setup graphing on the resources? It doesn’t seem to be as easy as clicking Memory, CPU, etc and then allowing it to graph..
Is in tool/Graphing add new.
When I do that it only shows the Interfaces . (WLAN , bridge-local, and ether’s . ) .
/tool graphing resource
add
I did that within terminal, and it added it. No idea why it isn’t part of http://192.168.88.1/webfig/#Tools:Graphing.Resource_Graphs .
For me it works!
It works now after the terminal command was used to turn it on.
I cut these commands from my saved export, but I entered them using the webgui.
So that is working as well.
