I made a network local (RB750Gr3 v7.21.3) to cloud (CHR-p1 v7.21.3) use l2tp-vpn.
and at the begining, i only have one ISP-WAN, i use this ISP-WAN to create vpn to the cloud node( three routeros nodes in the azure cloud ) ,everything is ok
now i get another two ISP-WAN , i wana make them as blance or backup mode
but i found a big problem , all the three ISP-WAN (ONU as the router and their lan ip address is the same 192.168.1.1/24), and i can not change the onu , so I just can use VRF to split them
in this situation , using different VRFs to do this include do a pcc blance for the lan users access internet has no problem ,but this time not the lan users ,but the routeros itself wana make vpn connection to the different cloud node passthrough different VRF , it doesn't work.
example:
cloud node1 111.0.0.10
cloud node2 112.0.0.10
cloud node3 113.0.0.10
configuration:
/ip vrf
add vrf=vrf2 interface=ether2
add vrf=vrf3 interface=ether3
/ip add
add address=192.168.1.2/24 interface=ether1
add address=192.168.1.2/24 interface=ether2
add address=192.168.1.2/24 interface=ether3
add address=1.1.1.1 interface=lo
#wana use this loopback ip address as source through from vrf ,But it seems that I cannot specify the source address for wireguard or pptp-client or l2tp-client ,I'm not quite sure about the principle of source address selection in these VPN protocols, or the principle of source address assignment in router systems
add chain=srcnat action=masquerade out-interface=ether1
add chain=srcnat action=masquerade out-interface=ether2
add chain=srcnat action=masquerade out-interface=ether3
/ip rou
add dst-address=0.0.0.0/0 gateway=192.168.1.1%ether1 routing-table=main
add dst-address=0.0.0.0/0 gateway=192.168.1.1%ether2@vrf2 routing-table=vrf2
add dst-address=0.0.0.0/0 gateway=192.168.1.1%ether3@vrf3 routing-table=vrf3
#and i wana connect cloud node2 112.0.0.10 through vrf2
#and i wana connect cloud node3 113.0.0.10 through vrf3
#i config like this, include out and back
#version1:
/ip rou add dst-address=112.0.0.10 gateway=192.168.1.1%ether2@vrf2 routing-table=main
/ip rou add dst-address=113.0.0.10 gateway=192.168.1.1%ether3@vrf3 routing-table=main
/ip rou add dst-address=1.1.1.1 gateway=lo@main routing-table=vrf2
/ip rou add dst-address=1.1.1.1 gateway=lo@main routing-table=vrf3
#version2: Recursive routing
/ip rou add dst-address=112.0.0.10 gateway=vrf2@vrf2 routing-table=main
/ip rou add dst-address=113.0.0.10 gateway=vrf3@vrf3 routing-table=main
all ping test were failed(source-address 1.1.1.1) ,configuration doesn't work , the vpn must be created in main routing-table ,because it will used for bpg and mpls
so I'm not sure if my configuration is wrong, my thinking is wrong, or the router simply doesn't support this mode, Please help me, thank a lot.
