How Donot Change Community In bgp
Hi Dear Friend If Annonce ip prefix To the Mikrotik router For example Community 2222:2222
this Router Annonce to uplink by no Community How In mikrotik Donot Rewrite Community ???
RouterOS does not change or remove communities unless you explicitly tell it to do this with routing filters.
If use filter For prefix Control any idea For donnot change Community ?
It would be helpful to see your configuration
