Hello.
I’m wondering how to create dynamic tunnels with some customers routers. For instance, I install a hap lite, or any wifi capable routerboard in customer home and would like that router to connect to our server. I currently do it with eoip tunnels but found it too much work creating a specific tunnel for each customer, is not bad if is only 5 or 10 but, when is more than that then it becomes a problem.
The basics: I need customers to connect via a L2 tunnel so I can add to a hotspot brige. Would like to just create a tunnel that would connect to the server no matter what the ip address of the customer is, in other words; the server doesn’t need to know the customer address and tunnel id as with EOIP. I’m running a routed network, I know it would be easier in a bridged network.
Please guide me in the right direction.
Thanks in advanced for your time.
