hi
can someone infrom me how far the 2.4GHz (MikroTik Product) signal will travel
thanks and regards
depends on the transmitter (radio card) + cable + antenna + height of the mast + visibility + the device on the other side. as you see in this forum section, there are people with 240Km links
hi
if we use
2.4Ghz Client Package with Integrated 18 dBi Antenna - RB/2018
how far it will travel
can we use this MikroTik product in pakistan because many people are using smartbridges products here in pakistan
5.1-5.8Ghz Integrated Router Antenna - RB133C + 22dBi Antenna - RIC/522C
thanks and regards
ayme
hi
how to use theser information in link test
can you please describe
i have only these information at this time..
RIC522C
MikroTik new product, low cost RIC/522C 5Ghz integrated antenna is ideal for CPE (client premise equipment) on 5Ghz Point-to-Multipoint networks. Also,pair of those can be used to create powerful 5Ghz Backbone (Point-to-Point link).
Specifications:
Integrated Antenna with RouterBoard 133c
RouterOS Level 3
802.11 a+b+g miniPCI Wireless Card
18V Power Supply and PoE injector
