Hi, how much bandwidth am I supposed to get through a hEX (RB750Gr3)? I currently only get around 100 Mbit/s with iperf3, 1-4 parallel streams, no additional parameters, no difference if 1 or 4 streams.
My IPSEC site to site connection has the following properties:
IKEv2
AES256-CBC
SHA256
MODP2048
Values are same for Proposal and Profile. The other side is a CHR VM which achieved a throughput of over 2 Gbit/s to another CHR VM.
I have already disabled connection tracking on both sides using Raw Firewall rules (action “no track” in both directions for the tunnel endpoint networks).
None of the CPU cores is at 100%, they are all below 50%.
CPU Profiler says the CPUs are mostly busy with networking.
According to installed SAs, hardware offloading is active.
Thanks!
