How have 2 pppoe router on the client side? whitout tunnels
Hello, when we install to or clients we use statios psubrigde, and then a wirless router.
How can we do it, when we have to routers? iknow i just can make tunnel, but this will be messi at the end. and wds it out?
Is it som other ways?
station pseudowire allows only one tunnel to be established.
yes iknow that, but if i set it on station mode, and brigde wlan whit eth1 og eth2 it will not work?. so is it any other whys do do it, whitout creating wds? or manual make eoip tunnels to every clients that have more then one pppoe tunnel?
bridged wireless in station mode is not going to work. If you don’t like wds, you can make vpls. here is an example
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_using_MPLS
