how i can acces wibox over the internet ?
hi..
i wanna acces winbox over internet … with change ip ddns but my problem is that im using 4 DSL whic goes into TP-LINK load balancer TL-R470T+ and its lan address 20.20.10.1 subnet 255.255.255.0
and mikrotkk wan address is 20.20.10.100/24
i add script .. but not working … i also forward port in every dsl with the name mikrotik and port 8291 udp and tcp both but stil im nat be able to access…
heres the script ..
/system scriptadd name=ddns policy=\
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
source="# HomingBeacon Main Dynamic DNS Update Script\r\
\n# Written by Sam Norris, ChangeIP.com\r\
\n# 20100728 Tested on RouterOS 4.9\r\
\n# 20110511 Tested on RouterOS 5.2\r\
\n\r\
\n# Set your specific ChangeIP.com preferences here.\r\
\n:global ddnsuser \"email\"\r\
\n:global ddnspass \"password\"\r\
\n:global ddnshost \"dnsdomain\"\r\
\n# Change ddnsport to 8245 to bypass proxy.\r\
\n:local ddnsport 8245\r\
\n\r\
\n# Do not edit anything below this line.  You have been warned.\r\
\n# Abusive updates to the system will cause firewall blocks.\r\
\n\r\
\n# Please be considerate and\r\
\n# do not let this script run more than once per 3-5 minutes.\r\
\n\r\
\n:log info \"DDNS: Starting.\"\r\
\n\r\
\n# Initialize checkpoint\r\
\n:global ddnscheckpoint\r\
\n:if ([:typeof \$ddnscheckpoint] = \"time\") do={\r\
\n\t:log info (\"DDNS: Last check was \" . ([/system clock get time] - \$d\
dnscheckpoint))\r\
\n} else={\r\
\n\t:log info \"DDNS: Cannot determine checkpoint, set now.\"\r\
\n\t:global ddnscheckpoint ( [/system clock get time] - 1d )\r\
\n}\r\
\n\r\
\n# Get the current IP\r\
\n:if ([/system clock get time] - \$ddnscheckpoint > [:totime 180s] || [/s\
ystem clock get time] - \$ddnscheckpoint < [:totime 0s]) do={\r\
\n   :log info \"DDNS: Performing remote IP detection.\"\r\
\n   /tool fetch address=\"ip.changeip.com\" host=\"ip.changeip.com\" src-\
path=(\"/\?\" . [/int eth get 0 mac-address ]) dst-path=\"ip.changeip.com.\
txt\" mode=http port=\$ddnsport\r\
\n   :global ddnscheckpoint [/system clock get time]\r\
\n} else={\r\
\n   :log info \"DDNS: Please be considerate and wait a few seconds longer\
.\"\r\
\n   :break\r\
\n}\r\
\n\r\
\n# Parse the IP address received from fetch script.\r\
\n\t:global ddnslastip\r\
\n\t:local html [/file get \"ip.changeip.com.txt\" contents]\r\
\n\t:local ddnsip [:pick \$html ([:find \$html \"\"] ]\r\
\n\r\
\n# Is it a valid IP and is it different than the last one\?\r\
\n\t:if ([:typeof [:toip \$ddnsip]] = \"ip\" AND \$ddnsip != \$ddnslastip \
) do={\r\
\n\t\t:log info \"DDNS: Sending UPDATE with \$ddnsip\"\r\
\n\t\t:log info [/tool dns-update name=\$ddnshost address=\$ddnsip key-nam\
e=\$ddnsuser key=\$ddnspass ]\r\
\n\t\t:global ddnslastip \$ddnsip\r\
\n\t} else={\r\
\n\t\t:log info \"DDNS: No update required.\"\r\
\n\t}\r\
\n}\r\
\n"
