i got one RB2011UiAS-IN switch, that used Athros AR8327 switch chip, follow that chip datasheet, i saw it can change the source/destination ip address in a ip package in hardware side (wire speed, no cpu required), but i checked the rule setting in RouterOS webfig switch option, there is no such action when you match a rule, only can do
Copy To CPU
Redirect To CPU
Mirror
Set New Dst. Ports
New Dst. Ports
New VLAN ID
New VLAN Priority
my question is as the ar8327 chip support such rules, is there a advance option can let me to make such rule (change a ip package source/destination address for example).
Thank you
