how I can configure openVpn client
because I have account on strongvpn.com website and they give me setting to connect it is call openvpn program and config file
how I can use this setting on Mikrotik
Note: I have five files in the config folder 2 with crt extension and 2 files with .key extension and one with .ovpn extension and all of this five files is require to connect
I have paid copy for mikrotik level 6 ver 3.23
and this a screen shoot for the router os
thank you
up :frowning:
as you see with the color red, you need to specify WHERE TO connect.
I know the Ip that I need to connect to but the problem is that I have 2 files in the vpn config with .crt extension but mikrotik have just one field for certificate
also where I can use the other 2 .key files
conclusion: I have this four files and I do not know where I can put them
1- XX.crt is the certificate authority
2- XX.crt - my client certificate
3- XX.key - my private key
4- XX.key is tls-auth key
I uploaded the files to server by ftp but where I can setup them
and the mikrotik setting what is AUTH and cipher is it keys files
thank you normis
I had update the router OS to the latest ver but it is still the same !
Import your CA certificate into the client
import your client certificate into the client
import your client private key into the client. Should end up with a “KR” next to it, use this certificate when connecting.
OpenVPN doesnt support TLS auth keys in MT for some reason.
Did you ever manage to get this working? I’m getting stuck.
