Hello
how are u ?
i want ask all friends he know about this problem ?
my client has "-70,etc i know that is not good signal strength ?
how i can get good signal strength , that is depend on what ?
What about the issue of “air time”?
If I have a 10 Mbps link, it will only take 1/5 of a second, instead of an entire second, to deliver the 2 Mbps.
I can use the other 4/5 of the second to serve other customers.
-70 is a pretty good target. Good enough for 54mb and plenty of headroom. If you don’t get a 54mb link with -70, something else is wrong.
To improve this, you need a better antenna.
And yes, a single weak client connection does affect the overall speed of the entire network, at least when its active.
I think he missed the part about air time.
pitty.. rotflmao
- I still stand by my previous statement.
- In physics, there are no facts, only theories.
- Drop the clichés and answer my question.
By you thinking about, and answering my question, we both learn.
Maybe you are right, maybe not. Maybe your logic is faulty, maybe mine is.
Don’t just say “I’m right and you are stupid.” Explain why you might be right.
