How i can kill connection?
Hello
How i can kill this connection?
Try many command variants - connection not killed.
Variant with
/ip firewall connection remove [find protocol=udp & dst-address=192.168.250.100 & connection-mark=trifle_conn_to_router
not work too
What if you use: && instead of & ?
/ip firewall connection remove [find protocol=udp && dst-address=192.168.250.100 && …
When use && instead of & required add :port parameter to dst-address and reply-dst-address arguments.
And not worked too…
How a can kill all unreplied connection by one command?
