Hi everyone. My question is here. I have a public IP pool adresses assigned to me by my provider, a complete C class.
Network scheme:
ISP GATEWAY (public space) → [wan (MK router RB450G) lan] → CLIENTS (private space)
I need assign public ip to my clients (not private ip, not NAT, not masquerading). All clients are located in my private space.
How can i assign public IP to private clients in routing mode (no bridge) without using NAT?
Lets say:
(examples ip)
ISP assigned publics ip (pool): 200.200.200.0/24
ISP Gateway (CISCO switch provided by ISP): 200.200.200.1
I need in a client (config example) put the follow config:
ip: 200.200.200.10 mask: 255.255.255.0 gateway: 200.200.200.1
Of course, I can config a simple bridge mode in MK, and it is working, BUT the bridge config is NOT a real solution for me, because I need isolate the space public and private at layer2 level. The public space and private space ONLY must communicate each other at layer3 level. Then (I think) I need a routing solution.
Any knows how I setup a routing mode (instead bridge) to make this possible? or any other solution?
Thanks in advance.
