Any Friend can teach me How to use Eoip OR VPN to connect Lans Games Between my shop and my home … Pls Help
i try to setting following that webside you give but i still cannot get it , i + bridge only can connect 1 server to 1 client ROS only ,.. any pro can teach me how i can connect 3client ROS ++ and above . And if i did use bridge i cannot see the Lans Games host in the Games .. is this ROS prosible to set like what i want ..?
If you need to create transparent bridge over 4 routers,
router1 router2 router3 router4.
If redundant link is required (one of the router disconnected from the public network, 3 others keep working without any problems),
create 3 EoIP tunnels on each router,
router1-router2
router1-router3
router1-router4
respectively for other routers.
Add to bridge local interface and 3 EoIP tunnels, enable RSTP protocol on the bridge.
