api port in 2.9.27 not found how ican add it to use mobile driod box
give me code or answer iam dont wont use any other verison okay
love all people
The published API was introduced in RouterOS 3. 2.9.x does not support the API. Sorry, but you will have to upgrade. Unless you are pirating the software, I can’t fathom why you would want to stick with such an ancient version of RouterOS anyway. Buy a copy of RouterOS 6 and upgrade.
– Nathan
thanks ok if you have mikrotik version 6 with serial and full where plz
use newer version of RouterOS.
