Hello!
Can you tell me how the Ethernet Cable is connected to the RIC/522E to be resistant against the weather?
I can’t take this information out of the pictures.
How reliable is this Cable Connection?
chris
Hello!
chris
Chris, Ethernet insulator should be provided with RIC/x kit, that ensures waterproof to antenna Ethernet cable.
Thanks Sergejs!
Can you tell me what type of connector this exactly is?
And how long is the Cable which is delivered with the RIC/522e?
I think it could be a E45V3 Connector like the one shown in this picture:
Thanks in advance,
chris
Ethernet insulator is like connector shown in the picture.
I do not know about cable length, probably you can length specify during the order process, but cable length should be accordingly PoE specification.
Is there a possibilty to get a Type of the Connector?
The Picture doesn’t make this clear to me…
For our deployment-plan it is absolutely important to know which Type of Connector is used in the RIC/522E.
christian
if i got you correctly then RJ45 (a bit shorter than standart ethernet connector)
Ethernet insulator looks like this:
1st part to protect Ethernet cable, 2nd part attached to integrated antenna.
Thank you sergejs! The picture is perfect.
Everything clear now!
Thanks a lot,
christian
