Hy,
i have a RB532A with a SR2 (backhaul, RB112 + SR2 on the other side) and a XR2 (hotspot). Never seen a problem with this platform, but…the signal, noise, SNR value reported by the XR2 is…comical!
Before the XR2, we have a SR2 for the hotspot, and it reported -101 to -105dBm for noise, and the client signal was correct.
Now, with the XR2, on same location, same cable, same antenna, it report -82dBm to -92dBm for noise value, and absurd values for the signal and SNR for the client.
An example: I have a client NLOS at about 1km, it report -92 to -101dBm for signal
, -8 to -20dBm for SNR
, but 90 to 100 for CCQ and a throughput (when it is the only client generating traffic on the network) of 4,5/5Mbps TCP half duplex (the network is a 802.11B).
I think there’s a bug on MT driver for this mPCI. Have you seen the same behaviour?
Regards
