I have internet+local proxy (like 172...*:3128) in office
can i use 951 mikrotik to make normal (no proxy) internet for make wifi got mobile devices?
is there some example?
Yes if you use default settings from the routerboard.
What do you mean with " for make wifi got mobile devices"
Grt
i have
172.17.12.1/25
gateway
172.17.12.1
and proxy
172.17.10.2:3128
and need make after 951
no proxy internet!
HOW i can do it?
You need to setup the same things that are in the. Default config. Then change the IP address DHCP network & ip pool. Check your ip firewall NAT rule and ensure it is matching your interface and not the 192.168.88.0/24 network.
Joshaven Potter
http://joshaven.com
Sent from my iPhone using Tapatalk
