how many clients can MT control simultaneously in hotspot
Good day pls, can someone tell me if he or she has used mikrotik with more than a million subscribers?
Also, should I have an ip address of 88.6.17.55 on which I have the hotspot service, what should be the subnet mask I use if I want to use the highest number of clients possible. Normally I would like to control 2 million clients. I call it WAH®. Who’s there please to give me a helping.
Thank you.
A bit early for April fools. Late Halloween prank?
actually, it is pretty hard to test something like this. i can’t even imagine what amount of RAM would be required. and you are planning what, to connect all two million users simultaniously, to one interface and one router???
You should be fine with MANY routers in load-balanced configuration with failover.
