How many connections max for an hap ac lite
I recently bought an hap ac lite, does anybody knows how many connections / users it can support ?
I’ve set the dhcp to 30 ip’s could it support that ?
Yes. But those are two different things…
How do you mean ? each ip is one device
Concurrently attached wireless clients and actually leased ip address list is not the same because of the lease time. Device which just have taken an ip is blocking further for some time it even after it has left the accesspoint. Normally does not make sense to restrict number of ip addresses that dhcp could provide. Better to use max station count parameter to limit number of physically connected WiFi devices if you would like to.
Finally a device can keep the wifi connection even without getting an ip address from the dhcp server. Because it could already have the ip by its own or because it does not need it.
