Hello All,
How many IP can I assign in an interface ? I mean how many aliasing IP addressing is possible over one Interface ?
Rafiq…
Hello All,
Rafiq…
as far as i know there are no limitations on how much ip addresses you can use on one interface - i have never ever hit the limitation.
anyway, how much you need?
you can create simple test:
create script that will add addresses to interface and additional rules what you need, and then you will see.
Thanks ,
I just configured my router a simple way for providing internet service.
----> public IP ----> ROUTER ----> private IP
I just assigned 6 private IP in my LAN interface and it is running well. It is also run very much well for assigning 7 or more IP in that interface.
But problem is limiting with queue. I cannot limit 7th IP/Network (as well more than 7th) that is assigned on LAN.
Link is going well but cannot shape the bandwidth for those IP/Network.
Need help.
Rafiq…
try using Mangle & Queues for limiting
what kind of limiting do you need?
Dear Chupaka,
That is BW limiting. Normally my other 6 network is running well without using mangle. That what happened on the 7th one.
And one thing for you .. " would you please change your picture, it looks odd, boobs are good but not that way ".
Sorry for comment such way.
Rafiq…
boobs ar good but not this way ? wich way do you prefer ? LOAD balance ?
lol … thas funny. ![]()
Load Balancing is OK
, If I include with it that’s great. Where free of INPUT AND FORWARD RULE
and lots of e-BGP.
Anyway, Chupaka still using the photo(Im sorry Chupaka). And I don’t get my answer
Rafiq…
oo my god Chupaka from boobs to baby .. ![]()
I prefer using Mangle - e.g. one can see conn marks in Connections
boobs appeared not to be load-balanced, so they are forbidden on MT forum =(
