How many S+RJ10 can be installed in CRS326-24S+2Q+RM
Hello!
Can you tell how many S+RJ10 transceivers can be installed into CRS326-24S+2Q+RM switch? Is it safe to install ones into all 24 ports of the switch?
Thank you!
…look at the PICs here: https://wiki.mikrotik.com/wiki/S%2BRJ10_general_guidance and the last section states:
Using the S+RJ10 Side by Side or with passive cooling devices
There might be situations when it is not possible to use the recommended layout of the transceivers. In such cases where two or more S+RJ10 transceivers are plugged in beside one another or modules are used in passive cooling devices, the network administrator has to ensure additional cooling. The air flow around the device should be increased or the overall ambient temperature should be lowered to keep the temperature of the transceivers within the recommended range.
Hence, even in the actively cooled CRS326-24S±2Q-RM, you should administer additional cooling
CSS/CRS326-24S+2Q+ – supports up to 12 simultaneous S+RJ10 modules.
https://wiki.mikrotik.com/wiki/MikroTik_wired_interface_compatibility#10G_SFP.2B.2F25G_SFP28
