How many simple queues does Mikrotik support?
Hi all!
Can you please tell me how many “simple queues” does Mikrotik support?
For example, 5k “simple queues” are supported by the system?
Starting from license kevel 3 (which is the lowest you can get for a purchased license) it is unlimited.
Practically it might depend on resources of your device.
It is easy to be found in the wiki/help pages.
Thanks for the clarification!
