remember that if you have a 10Mbit link connected to the access point and the access point itself is 11mbit (in reality about 6) then just imagine what a pain it is to be one of those 100 who divide this between themselves …
theoretical maximum is 2007. others please share your experience regarding this.
We work on a 40:1 contention so 100 customers using a 6Mb link at 512k each is more than enough!!
I’d be interested to hear of real world scenarios where you have an 802.11b radio and lots of customers.
To date I have used SmartBridge AP’s and these start to run out of steam with more than 35 customers - I’d like to have a MikroTik AP with a high end motherboard, processor and memory hopefully increasing the above 35-40 limit of the SmartBridge AP’s.
they have their fiber optics which they then divide with 100mbit hubs/switches. this usually works in rural areas where there are a lot of homes (apartment buildings). here is the latvian internet exchange sheme: http://www.lix.lv/shema/shema.htm but this is kind of off-topic
Bandwidth isn’t the bottleneck really, it’s the half duplex nature of 802.11b (nstream cures this).
You have to treat an AP as a conventional class 1/11 repeater, you wouldn’t throw too many people on a single segment, most cases you’d limit each segment to 12 seats. This is not exactly correct as a repeater is using CSMA/CD, and an AP is using CSMA/CA, so it would be like a hybrid ethernet/tokenring network as the AP can poll clients if they reach set thresholds.
Another thing that tends to nail wireless is small packets, if you have a client throwing >100packets/sec at the AP and maybe consuming less than 10kB/sec, they’re still going to cause the AP to struggle with the load. So having lots of clients giving out the occational burst of small packets can tie things up a bit. Unless you’re using ‘packet packing’ between MTRouters etc.
Anyway, to answer the question the most amount of clients I have on a single AP (single channel) is ~25.
So it’s probably better if you have multiple wireless interfaces with sectorised antennas when operating in high density areas.
And for those in Latvia, send some bandwidth down this way!
