I am creating a network, which uses multiple VLANs and many ports in switches are “trunked” - should get tagged traffic from all VLANs.
Right now, I have a VLAN bridge for each of the VLANs with all the trunked ports specified as tagged. If I want to turn an access port into a trunked port (or vice versa), I have to go to each of the VLAN bridges and add/remove the port in question from the list of tagged ports. As you can imagine, this is quite annoying and causes some unnecessary error-proneness.
I would like to have something like an interface list with all the trunked ports and then add this list to all the VLAN bridges as a tagged port - this means that to add or remove a trunked port, I’d just have to add/remove it to/from the interface list, instead of doing so for each VLAN bridge.
Is this even possible or do I have to stick with specifying al the tagged ports for each VLAN bridge?
Thank you very much in advance.
GS
