How remove a port from a Lacp group
Hi
I added four ports to a Lacp group. They work fine.
Now I want remove One or two ports from this group but I can’t find how to do it.
I’m on the latest firmware version and the switch is a CSS326
For each port that you want to remove from the LACP group, change the mode from “Active” or “Static” to “Passive” on the switches at both ends in the LAG tab.
