Hello
How RouterOS establish port mirroring?
Hello
NAT is used to redirect data from public ports to local ports.
I want Switch Port Mirroring
No that。
I am a Chinese. My English is poor.
do you mean - bridge?
give detailed explanation, what do you mean by ‘port mirroring’.
I think he’s refering to the feature in cisco where you can select a port on the switch and have all its data sent to the port + another.
Its a very stealthy way of capturing traffic
Yes it’s a standard feature on L3 managed switches, even the cheap ones from Netgear etc. There are a number of reasons for doing this including trouble-shooting and network management
I would imagine it’s possible to implement in ROS but it’s not there yet AFAIK.
Experts may want to comment …
Regards
Monitoring Port
You should really use a switch, not a router, to do this. Although you can setup packet sniffer and stream the packets to another station.
