How secure is IPIP tunel ?
Hi guys.
Just made a IPIP tunel, works fine.
How secury is it ? do I need to setup something else ?
As I see, it works in pairs, so there is no way for someone else connect in the middle, correct ?
How about package loss, is it fine ? do I need to change some config in other to have a IPIP faster & less package loss ?
I have a RB450G with RouterOS 6.2
cheers
IPIP has no security whatsoever.
To make it secure you need to use Ipsec encryption.
IPIP tunnel works fine. I am using IPIP tunnel from last four years & no problem.
+1.. Secure it with IPSec.
Sent from my SCH-I545 using Tapatalk 4
