Hello community!
I´m from Brazil and my english is poor.
Thank you for any help…
I try this script below but it don´t work:
require(‘routeros_api.class.php’);
$API = new routeros_api();
$API->debug = true;
// user test
$ip = ‘xxx.xxx.xxx.xxx’;
$usuario = ‘teste4’; // full same admin
$senha = ‘123456’;
if ($API->connect($ip, $usuario, $senha))
{//I intent set the name of user above
$API->write(‘/user/set teste4
=name=teste3’);
$API->disconnect();// i try connect with new name/user
$usuario = ‘teste3’;
$senha = ‘123456’;//Here can´t connect
$API->write(‘/interface/getall’);$ARRAY = $API->read();
print_r($ARRAY);
$API->disconnect();
The answer;
Connection attempt #1 to 192.168.200.221:8728…
<<< [6] /login
[5/5 bytes read.
[5, 39] !done
[37/37 bytes read.
[37, 1] =ret=e03816502927efa864b8a4ba6431b029
<<< [6] /login
<<< [12] =name=teste4
<<< [44] =response=00c2b343666183c7d5f34d1c1a4a5bc764
[5/5 bytes read.
[5, 1] !done
Connected…
<<< [16] /user/set teste4
<<< [12] =name=teste3
Disconnected…
<<< [6] /login
[5/5 bytes read.
[5, 39] !done
[37/37 bytes read.
[37, 1] =ret=13284cdfc26c2827f6546815d976fa06
<<< [6] /login
<<< [44] =response=004c48a00835dbc34a312ddfcd544ecdd9
[5/5 bytes read.
[5, 31] !trap
[22/22 bytes read.
[22, 8] =message=cannot log in
[5/5 bytes read.
[5, 1] !done
Connection attempt #2 to 192.168.200.221:8728…
<<< [6] /login
[5/5 bytes read.
[5, 39] !done
[37/37 bytes read.
[37, 1] =ret=afa644dff9667c92fbb42327d19bd16c
<<< [6] /login
<<< [44] =response=00ff7abf6c0c2852079b86832eca464754
[5/5 bytes read.
[5, 31] !trap
[22/22 bytes read.
[5/5 bytes read.
[5, 1] !done
Connection attempt #3 to 192.168.200.221:8728…
<<< [6] /login
[5/5 bytes read.
[5, 39] !done
[37/37 bytes read.
[37, 1] =ret=82723729cf850399c10051f6e80c407b
<<< [6] /login
<<< [44] =response=00cd86c6e6ba00d5e47ac1615d08491335
[5/5 bytes read.
[5, 31] !trap
[22/22 bytes read.
[5/5 bytes read.
[5, 1] !done
Connection attempt #4 to 192.168.200.221:8728…
<<< [6] /login
[5/5 bytes read.
[5, 39] !done
[37/37 bytes read.
[37, 1] =ret=525e65e4820f61d2505b6c38ebf82208
<<< [6] /login
<<< [44] =response=00d5a43d2f1cfb3732e91a9f291ee30582
[5/5 bytes read.
[5, 31] !trap
[22/22 bytes read.
[5/5 bytes read.
[5, 1] !done
Connection attempt #5 to 192.168.200.221:8728…
<<< [6] /login
[5/5 bytes read.
[5, 39] !done
[37/37 bytes read.
[37, 1] =ret=595652cd89f96a3b7c85616e660de100
<<< [6] /login
<<< [44] =response=00272ecd8ba933b95e7d37d4a72e49d197
[5/5 bytes read.
[5, 31] !trap
[22/22 bytes read.
[5/5 bytes read.
[5, 1] !done
Error…
------------------------------ Any body help?
