Hello!
I try to run a VPS server as wireguard vpn server and get access to this VPN server via my local network on mikrotik router.
The wireguard IP range is 10.9.0.0/24
And the local network on my mikrotik is : 192.168.7.254/21
I want the VPS have a gateway with wireguard to my local network and can ping it and forward packets to server at home.
But : on Mikrotik I see that the connection is established, but there is no ping from VPS and no packets are sent.
VPS config
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 52:54:00:17:b8:98 brd ff:ff:ff:ff:ff:ff
altname enp0s3
inet 185.230.143.197/32 brd 185.230.143.197 scope global ens3
inet6 2a12:5940:b271::2/48 scope global
inet6 fe80::5054:ff:fe17:b898/64 scope link
5: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.9.0.0/24 scope global wg0
iptables
iptables -t nat -A POSTROUTING -s 192.168.7.254/21 -j MASQUERADE
Wireguard Config on VPS :
[Interface]
Address = 10.9.0.0/24
ListenPort = 9000
PrivateKey = aaaaaaaaaaaaaaa
[Peer]
PublicKey = xxxxxxxxxxxxxxx
PresharedKey = yyyyyyyyyyyyyyy
AllowedIPs = 10.9.0.0/24, 192.168.0.0/21
PersistentKeepalive = 25
Mikrotik Configs :
/interface wireguard
add listen-port=9000 mtu=1420 name=wireguard
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=185.230.143.197 endpoint-port=\
9000 interface=wireguard name=peer1 persistent-keepalive=25s \
preshared-key="aaaa" private-key=\ "bbbbbb" public-key=\ "cccccccc"
add address=192.168.7.254/21 comment=LAN interface=LAN-Bridge network=\
192.168.0.0
add address=10.9.0.2/24 interface=wireguard network=10.9.0.0
/ip firewall address-list
add address=8.8.8.8 comment=DNS list="Trusted IPs"
add address=77.88.8.8 comment=DNS list="Trusted IPs"
add address=185.230.143.197 comment="VPS my" list="Trusted IPs"
add address=10.9.0.0/24 comment=WG list="Trusted Networks"
add action=accept chain=input comment="Trusted Networks" src-address-list=\
"Trusted Networks"
add action=accept chain=input comment="Trusted IPs" src-address-list=\
"Trusted IPs"
add action=accept chain=input comment=LAN in-interface=LAN-Bridge
add action=accept chain=forward comment="route accept" in-interface=ether1 \
ipsec-policy=in,ipsec
add action=drop chain=input comment="Drop All" src-address=!91.219.166.119
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard \
routing-table=wg scope=30 suppress-hw-offload=no target-scope=10
